软件版本:5.6.0
问题描述:3Dslicer中radiomics特征提取不出来,电脑语言也是英文,路径也全是英文,apply后working了几秒就没了,没有结果,然后几天前成功过一次之后,忘记调整了哪里,之后再也分析不出来了,
提取后右下角红色×报错显示这个
.Done
[2023-12-09 18:05:28] I: radi omios. seript: Starting PyRadi omios (version: v3. 1.0)
[2023-12-09 18:05:28] I: radi omios. seript: Processing input.
[2023-12-09 18:05:28] E: radi omies. seript: Error extracting featur es!
Traceback (most recent call last):
File "E: 13dslicer lslicer 5.6.01slicer. org\Extensions-323901slicerRadiomios\Liblsite-
packagesiradi omieslsoriptsl_init_.py",line 135,in run
results=self.processCases(caseGenerator)
File "E:\3dslicer islicer 5.6.0\slicer. org\Extensions-32390\slicerRadi omics\Liblsite-
packageslradiomieslseriptsl_init_.py",line 233,in_processCases
setting_overrides = self. parseOverrides()
File "E: 13dslicer islicer 5.6.0)slicer. org\Extensions-32390\slicerRadi omics\Libisite-
packagesiradi omicslscriptsl_init_py*, line 353, in parseOrerrides
settingsSchema = yaml. safe_load(schema)['mapping'][setting']t'mapping']
File "E:\3dslicer\slicer 5.6.0\slicer.org\Extensions-32390\slicerRadiomios\Liblsite-
packages lruamel lyaml lmain. py", line 1105, in safe_load
error_deprecation('safe_load','load',arg"typm'safe', pure-True")
File "E: 13dslicer islicer 5.6.01slicer. org\Extensions-32390islicerRadiomios\Libisite-
packaresirusmellyanlimain.py",line 1037,in error depregation
谢谢各位老师,已经后台修改编程代码了,已经能够运行了,谢谢大家,需要定义一下353行的代码加提示的那个代码复制上去
我遇到了相同的问题,请问你是怎么解决的?
Params.yaml (365 字节)
