为什么python 3.13安装pyradiomics总是失败,试了各种方法都不行
为什么python 3.13安装pyradiomics总是失败,试了各种方法都不行。镜像网站试了,aconda也试了,就是不知道哪错了问题。
这是报错信息:
Collecting pyradiomics
Using cached pyradiomics-3.1.0.tar.gz (34.5 MB)
Installing build dependencies: started
Installing build dependencies: finished with status ‘done’
Getting requirements to build wheel: started
Getting requirements to build wheel: finished with status ‘done’
Preparing metadata (pyproject.toml): started
Preparing metadata (pyproject.toml): finished with status ‘done’
Discarding https://files.pythonhosted.org/packages/03/c1/20fc2c50ab1e3304da36d866042a1905a2b05a1431ece35448ab6b4578f2/pyradiomics-3.1.0.tar.gz (from https://pypi.org/simple/pyradiomics/): Requested pyradiomics from https://files.pythonhosted.org/packages/03/c1/20fc2c50ab1e3304da36d866042a1905a2b05a1431ece35448ab6b4578f2/pyradiomics-3.1.0.tar.gz has inconsistent version: expected ‘3.1.0’, but metadata has ‘3.0.1a1’
Using cached pyradiomics-3.0.1.tar.gz (34.5 MB)
Preparing metadata (setup.py): started
Preparing metadata (setup.py): finished with status ‘error’
error: subprocess-exited-with-error
python setup.py egg_info did not run successfully.
exit code: 1
[38 lines of output]
D:\WibdowsTEMP\TEMP\pip-install-1er79fv_\pyradiomics_49c7d097d5ea49e7ab87a047294d08d2\setup.py:9: SetuptoolsDeprecationWarning: The test command is disabled and references to it are deprecated.
      Please remove any references to `setuptools.command.test` in all supported versions of the affected package.
      This deprecation is overdue, please update your project and remove deprecated
      calls to avoid build errors in the future.
from setuptools.command.test import test as TestCommand
D:\WibdowsTEMP\TEMP\pip-install-1er79fv_\pyradiomics_49c7d097d5ea49e7ab87a047294d08d2\versioneer.py:418: SyntaxWarning: invalid escape sequence ‘\s’
LONG_VERSION_PY[‘git’] = ‘’’
Traceback (most recent call last):
File “”, line 2, in
exec(compile(‘’’
# This is – a caller that pip uses to run setup.py
…<31 lines>…
exec(compile(setup_py_code, filename, “exec”))
‘’’ % (‘D:\WibdowsTEMP\TEMP\pip-install-1er79fv_\pyradiomics_49c7d097d5ea49e7ab87a047294d08d2\setup.py’,), “”, “exec”))
File “”, line 34, in
File “D:\WibdowsTEMP\TEMP\pip-install-1er79fv_\pyradiomics_49c7d097d5ea49e7ab87a047294d08d2\setup.py”, line 79, in
version=versioneer.get_version(),
File “D:\WibdowsTEMP\TEMP\pip-install-1er79fv_\pyradiomics_49c7d097d5ea49e7ab87a047294d08d2\versioneer.py”, line 1476, in get_version
return get_versions()[“version”]
File “D:\WibdowsTEMP\TEMP\pip-install-1er79fv_\pyradiomics_49c7d097d5ea49e7ab87a047294d08d2\versioneer.py”, line 1408, in get_versions
cfg = get_config_from_root(root)
File “D:\WibdowsTEMP\TEMP\pip-install-1er79fv_\pyradiomics_49c7d097d5ea49e7ab87a047294d08d2\versioneer.py”, line 342, in get_config_from_root
parser = configparser.SafeConfigParser()
AttributeError: module ‘configparser’ has no attribute ‘SafeConfigParser’. Did you mean: ‘RawConfigParser’?
[end of output]
note: This error originates from a subprocess, and is likely not a problem with pip.
error: metadata-generation-failed
Encountered error while generating package metadata.
See above for output.
note: This is an issue with the package mentioned above, not pip.
hint: See above for details.
问题分析
pip install pyradiomics 在 Python 3.13 上会撞上两个还没修好的坑:① Python 3.12 起彻底移除了 configparser.SafeConfigParser,而 PyRadiomics 仍携带老旧的 Versioneer 脚本调用它;② PyPI 里的 3.1.0 源码包带错了内部版本号(3.0.1a1),pip 把它当成“损坏”包直接丢弃。两个问题叠在一起,安装自然失败。当前官方发行版仅保证到 Python 3.11(甚至文档里还停在 3.9),因此最简单、最稳妥的办法就是在 conda/venv 里切回 3.11 或更早,并从 conda‑forge 或预编译 wheel 安装。下面把原理和可选解决方案按步骤列出来。
1 为什么 Python 3.13 会装不上
1.1 SafeConfigParser 已被删除
  • Python 3.12 把 configparser.SafeConfigParser 与 readfp() 一并移除;任何还在调用它们的旧代码都会抛 AttributeError (GitHub, GitHub)。
  • PyRadiomics 使用的 Versioneer 0.21 写于 2020 年前后,内部硬编码了 SafeConfigParser,因此在 3.12+ 触发上述错误 (GitHub)。
1.2 源码包元数据不一致
PyPI 上标识为 pyradiomics‑3.1.0.tar.gz 的包里头却声明版本 3.0.1a1,pip 检查到不一致就会 “Discarding … inconsistent version”,正好与你的日志对上 (GitHub)。这说明官方发布流程本身也需要修补。
2 官方目前支持到哪一版 Python?
  • 官方文档和 Release Notes 只列出 3.7–3.9 (最近一次打包时 CI 还停在这些版本)(pyradiomics.readthedocs.io, pyradiomics.readthedocs.io)。
  • PyPI 页面里预编译的 wheel 也只到 cp311 (Python 3.11)为止 (Wheelodex)。
  • GitHub 上已有用户在 3.12 报同样的问题,但维护者尚未合并修复 PR (GitHub)。
结论:3.12/3.13 暂时属于“未测试 / 不支持”。
3 最省事的解决方案——切回稳定版 Python
场景 推荐动作 关键命令
conda 用户 建立干净环境并安装预编译包 conda create -n radio311 python=3.11 pyradiomics -c conda-forge
pip/venv 用户 用 pyenv 或官方安装包下个 3.11,再装 wheel bash\npython3.11 -m venv venv\nsource venv/bin/activate\npip install --upgrade pip\npip install pyradiomics==3.1.0\n
需要脚本化部署 在 Docker 里锁定 3.11 基础镜像 FROM python:3.11-slim
这样可以直接用到官方 wheel,省去本地编译 C 扩展的麻烦,也不用碰 Versioneer (PyPI)。
4 仍想在 Python 3.13 上使用的两条路
:warning: 都属“手动打补丁”,生产环境不建议。
4.1 自己打补丁 + 本地安装
git clone https://github.com/Radiomics/pyradiomics.git
cd pyradiomics
# 更新 Versioneer,替换对 SafeConfigParser 的调用
python -m pip install --upgrade pip setuptools_scm
# Quick‑fix:把 versioneer.py 中 SafeConfigParser → ConfigParser,readfp → read_file
sed -i "s/SafeConfigParser/ConfigParser/g" versioneer.py
sed -i "s/readfp/read_file/g" versioneer.py
python -m pip install .
原理同社区用户给其他包打补丁的做法 (GitHub, GitHub)。
4.2 等待(或协助)官方合并 PR
GitHub 已有针对 Python 3.12/3.13 的修复 PR,由于项目活跃度一般,短期内可能还需手动从 fork 安装:
pip install git+https://github.com/<your-fork>/pyradiomics@py312-fix
5 额外提示
  1. 不要混用全局 pip 与 Anaconda:同一机器可以并存,但环境要隔离,否则 python.exe 指向哪个版本很容易搞混。
  2. 仍想用 3D Slicer?
  3. 自动化构建:如果你在 CI/CD 里用 pip install pyradiomics,务必先 actions/setup-python 选择 ≤ 3.11,避免后续脚本失效。
  4. 关注官方 issue #893 / #886:一旦维护者释放新的 wheel,你就可以直接回到 pip install pyradiomics (GitHub, GitHub)。
6 小结
PyRadiomics 目前并未适配 Python 3.12+;核心阻碍是旧 Versioneer 对 SafeConfigParser 的调用,以及 3.1.0 源码包的元数据错误。
首选方案:在隔离环境中退回 Python 3.11(或 Slicer/Radiomics Docker),直接用官方 wheel。
实验方案:手动 patch Versioneer 或从带修复的 fork 编译安装。
等待官方正式支持前,这两步可以让你继续使用 PyRadiomics 而不被语言升级卡住。
