软件版本:5.12.3
问题描述:能导入图像,也可以读取数据但是最后勾画完成之后,用Radimics计算只有表头
日志…Done
[2026-09-05 23:53:31] I: radiomics.script: Starting PyRadiomics (version: 3.1.0a2.post10+g146e3bd)
[2026-09-05 23:53:31] I: radiomics.script: Processing input…
[2026-09-05 23:53:31] I: radiomics.featureextractor: Loading parameter file D:/AppGallery/Downloads/3dSLICER/Temporary diretory\RadiomicsLogicParams.json
[2026-09-05 23:53:31] I: radiomics.featureextractor: Applying custom setting overrides: {‘label’: 1, ‘correctMask’: True}
[2026-09-05 23:53:31] I: radiomics.script: Input valid, starting sequential extraction from 1 case(s)…
[2026-09-05 23:53:31] I: radiomics.script: Processing case 1
[2026-09-05 23:53:31] I: radiomics.featureextractor: Calculating features with label: 1
[2026-09-05 23:53:31] I: radiomics.featureextractor: Loading image and mask
[2026-09-05 23:53:31] E: radiomics.script: Feature extraction failed!
Traceback (most recent call last):
File “D:\AppGallery\Downloads\3dSLICER\3D Slicer 5.12.3\slicer.org\Extensions-34627\SlicerRadiomics\Lib\site-packages\radiomics\scripts\segment.py”, line 70, in _extractFeatures
feature_vector.update(extractor.execute(imageFilepath, maskFilepath, label, label_channel))
File “D:\AppGallery\Downloads\3dSLICER\3D Slicer 5.12.3\slicer.org\Extensions-34627\SlicerRadiomics\Lib\site-packages\radiomics\featureextractor.py”, line 272, in execute
image, mask = self.loadImage(imageFilepath, maskFilepath, generalInfo, **_settings)
File “D:\AppGallery\Downloads\3dSLICER\3D Slicer 5.12.3\slicer.org\Extensions-34627\SlicerRadiomics\Lib\site-packages\radiomics\featureextractor.py”, line 385, in loadImage
mask = imageoperations.getMask(mask, **kwargs)
File “D:\AppGallery\Downloads\3dSLICER\3D Slicer 5.12.3\slicer.org\Extensions-34627\SlicerRadiomics\Lib\site-packages\radiomics\imageoperations.py”, line 56, in getMask
raise ValueError(‘No labels found in this mask (i.e. nothing is segmented)!’)
ValueError: No labels found in this mask (i.e. nothing is segmented)!
[2026-09-05 23:53:31] I: radiomics.script: Processing results…
[2026-09-05 23:53:31] I: radiomics.script: Finished segment-based extraction successfully…
