2018 年7 月 6 日 13:52
给出几个官网的帖子
I’ve tried to load an MRI study from DICOM that contained DWI series (Slicer 4.8.1 on Windows). Although I’ve installed SlierDMRI extension, the series was still loaded using scalar volume importer and appeared garbled. Is this behavior expected?...
Reading time: 2 mins 🕑
Likes: 4 ❤
(Hi @ElonKou, I combined both of your messages in one thread) Based on the screenshot in this message, please try loading the following series only: ep2d diff mddw 64 cor (series 9) All of the other ones with a longer name (like ep2d diff mddw 64...
解决方法:Thank you very much for your help. I have already solved this problem.
I read all the pixel-data, gradients, bvalues from the dicom series and wrote them all to the dwi node. Then I get the dwi-node ,and can use it to continue my reconstruction of the DTI-neurons. Thank you again for your help.
Hi sir. When I use the module DWI Convert (Slicer 4.7.0), Dicom to Nrrd, and click Apply, it always shows the error as follows and I can’t convert the dicom data to nrrd: Diffusion-weighted DICOM Import (DWIConvert) standard error: **Exception...
I tried the same with different data and now it is saying: Description: ImageIO returns IO region that does not fully contain the requested regionRequested region: ImageRegion (0x7fff5fbf9c10) Dimension: 3 Index: [0, 0, 0] Size: [400, 512, 1]...
I am having some trouble importing dicom files and converting them to dwi. I saw a few threads in the forum on this issue (for example, this, this). I get the same error, which says “itk::ERROR: LoadFromDisk not relevant”. These files can be loaded...
Reading time: 1 mins 🕑
Likes: 1 ❤
I am having difficulty converting DICOM files to nrrd using the DWIConvert module. The following command gives the output below: DWIConvert --inputDicomDirectory /path/to/dicom/files --outputVolume output.nrrd ======= DWI Convert Public Lib Ctest...
Likes: 1 ❤
Likes: 1 ❤
Dear Users, My name is Ors Petnehazy and I’m interested in 3D veterinary anatomical reconstrucions. I know some features of the Slicer. I made some reconstructions already (air sacs, horse stifle CT, MR, etc.). For a research project I need to...
This is a trace image: It looks like you are using the Siemens product sequence, which should work fine, but you need the original DWI images (these derived maps are automatically computed by the scanner by default, but it can be turned off in the...
Hello, I am able to run DWI Convert for FSL to NRRD conversion with no input volume by selecting allow lossy conversion on DWIConvert 4.7.1. When I run DWI Convert with the same parameters in version 4.8.0, I get the following error: ...
Likes: 1 ❤
Hi all Is it possible to calculate FA of the liver by 3D slicer? i’m trying to do that by instructions (DiffusionMRIanalysisTutorial_Slicer4.5_SoniaPujol) Unsuccessfully Thank you!
Likes: 2 ❤
